Abs delete
DallasTahoe
DallasTahoe
Use a Motiv pressure bleeder and you'll wonder why you never bought one before. It attaches to the mc and you fill it with up to 1/2 gallon of fluid , pump it up by hand and you can bleed all 4 brakes just by putting a clear tube on the bleeders and cracking them open. The mc automatically stays full. Watch the fluid and bubbles flow out. So easy it's ridiculous.
I looked at the Motiv bleeder and yes it looks awesome but for the number of times I would use it I can’t justify the cost, and trust me I’ve got a lot of stuff in my garage where I should have said that
I struggled with that too. For years. And meanwhile I bought one of the vacuum ones that hook to a compressor and wasted a gallon of brake fluid and an entire day trying to bleed my brakes and ended up returning it and doing it the old fashioned way. Then next time when I was installing my Wilwoods I decided wtf, compared to the cost of my brakes it was nothing. Now I wish I'd have bought it years ago. Even if I only need it twice in my lifetime it's worth it.
rabbiporkchop
Pennsylvania
I used this for bleeding.
http://www.tooldiscounter.com/ItemD...MI7dfti8bi1wIVzIKzCh0iKAk2EAQYAiABEgK33fD_BwE
DallasTahoe
DallasTahoe
Decided I’m going to go through with the delete and do that before making the jump to hydroboost. My brakes are just too inconsistent and I know it’s because of that pesky abs module. I just need to know the thread on the abs input lines so I can get the proper adapters anybody know?
NWguy
NWguy
anyone here ?
I have a 2000 Z71 and the ABS module has been removed and piped the front disc in direct and the rear going through a wilwood manual adjustable for rear drums... It doesnt work pedal goes to the floor ..its been power bled and everything...Ive had several different shops attempt fixing this . everyone wants to change the MC with no results.. thanks
DallasTahoe
DallasTahoe
Do new stainless steel lines in front and rear, then make sure the rear brakes are adjusted properly, then bleed them
Zillaroscoe
I deleted my abs module and installed a proportional valve. They make adjustable one, Wildwood has a good one but can also get a basic one from most parts stores. Alot easier than it sounds and much easier to stop with.
blondie70
I have an '02 F-150. Due to brake dragging problems, I removed the ABS module. I ordered replacement headers for the brake lines to the module from "Big Billet". No proportioning valve. Brakes are good. Pulled the dash apart and painted over the ABS light. All ok now.
Don't know if they make one for Chevys, but I bet they do........good luck
iaminfiji
