ABS light came on today
raptorforme93
Tampa, Fl
I was on the highway doing about 70-85mph in my 96 hoe today and I noticed that my abs light came on. It has never been on and I have never even locked up my wheels since my brakes dont have the balls to even stop my truck. I havent noticed any change in the way the brakes feel or anything but I am worried about it. What could be wrong and should I get it checked out immidiately or can I check it out myself??
Bad bow tie
Grizz Straight FTMFW
Michigan/NC
Check the connector on the wheel bearing. Its a cable that runs from the wheel bearings and it should be underneath the wheel well guard on the front. (Both tires) Disconnect it and check for corrosion, and if there is any clean it and see if that helps. Depending on how old the wheel bearings are and how many miles they have on them, you may need to replace them. But it's an easy job. They're really not cheap, but you could probably do it yourself.
raptorforme93
raptorforme93
Tampa, Fl
And to add to it today I was driving at night with my windows down in the cool air and I noticed a slight clicking noise that sounded like it was coming from the front end. It would increase with speed and would go away if I applied any pressure to the brakes at all and would come back when I let off. I have never heard it before and it may be totally unrelated but i thought that i would add that. I will check out the connections tomorrow after I get home from school. Thank you!
raptorforme93
raptorforme93
Tampa, Fl
Do I have to have a shop get the codes or is there a device I can buy to give me the codes or?... Im sorry still getting into car maint. Im very mechanically inclined though, im just not used to working on a v8 engine or on my hoe
Bad bow tie
Michigan/NC
You have an OBDII system so you can go to autozone and have them check it for free. Not sure it will work with an ABS light though.
TNtahoeB
Tennessee
The code readers at autozone won't read ABS codes. You will need to have someone with a scanner look at it. With the right computer they can go in and theirs will show exactly what the ABS system is doing to throw the code. If they know what they are doing they should be able to pin-point the problem.
raptorforme93
raptorforme93
Tampa, Fl
Alright well im pretty good friends with the guys down at the local shop so Ill see what they can do for me. Thanks for the help guys
raptorforme93
raptorforme93
Tampa, Fl
I got the codes scanned today. It looks like my left front abs sensor and rear center speed sensors are not working. They quoted me $370 in parts. How much do those damn things cost?? Are they hard to replace?
cshupe
ABS Light
Could be a wheel speed sensor. Mine did that recently and the part was about 35 from the dealer and the light went away.
mello1420
