ABS RF wheel activation
mortten
Boy just picked up an 06 Yukon Denali. ABS and TC lights were on. Scanned it and had a RF Sensor circuit code. Found the sensor unplugged. Now it know why. Plugged it back in. No more codes. All sensors reading the same speed. When pulling away from a dead stop the RF activates. Let off the gas and then it goes fine. Sets no codes. Head scratcher.
M
mortten
I graphed them. Didn’t notice a drop out but wasn’t looking that hard at that point. Looks like the hub was replaced recently. It’s tight and no rust on the hub face. I pulled the sensor. Wasn’t rust jacked. There’s a turn cv boot so I have to pull the axle. I’ll clean up the tone ring and go from there. Doesn’t appear to be a factor sensor.
You can clean the redactor within the hub by using a Q-Tip with brake cleaner, while rotating the hub. Sometime something gets in there and interferes with the sensor/redactor operation.
Just a little FYI--I've found out that you need to use the correct abs wheel sensors that come with the hubs. In other words--you can't use an Timken hub with a GM wheel sensors. It'll plug in but it doesn't work. Unfortunately you can't mix and match if you're trying to troubleshoot. I don't know what that is.
M
mortten
Just a little FYI--I've found out that you need to use the correct abs wheel sensors that come with the hubs. In other words--you can't use a Timken hub with a GM wheel sensors. It'll plug in but it doesn't work. Unfortunately you can't mix and match if you're trying to troubleshoot. I don't know what that is.
Don’t know about that. The side in question has a newer Carquest hub on it. The left hub was bad so I replaced it with a Mevotech unit. I also replaced both front sensors with GM sensors discarding the ones that came with the hubs. Everything works fine now. In my experience GM vehicles hate any aftermarket sensors. I use strictly OEM sensors on everything anymore.
CoyotesRUS
