AC air vent block issue!!!
P
PlunkZ71
Long trips makes sense. Air doesn't have *that* much moisture in it and it'll take a bit to plug it up with ice such that you notice airflow problems.
Under what conditions were you measuring those pressures? Fan speed, ambient temp, RPM, vent temps (use a meat thermometer not infrared) and whether or not you're experiencing the icing issue
Pressure was measured at 98 degrees ambient temp at idle. Didn't have a thermometer in the vent. Did Not note the fan speed or RPM
Djohnson99
