AC Compressor & Accumulator P/N's
pstuffy
Does anyone have the GM p/n's for the following list for a 2001 Tahoe 5.3L with rear ac:
(1)AC Compressor
(2)Accumulator/Dryer
(3)AC Orifice Tube
(4)Orings to complete a swap of the above parts
AC compressor is on its last legs and want to swap it out. Any tips or other parts I need would be greatly appreciated as well.
SunlitComet
OBS Jedi-Do Good
unknown at this time.
(1)AC Compressor
COMPRESSOR ASM,A/C
Part Number: 15-21127
Product Notes:
AC Compressor
Low mtg, denso ; A/C Man Cont (C60) ; A/C Auto Elec Cont (C68) ; RR Aux, A/C (C69)
Per Vehicle: 1; Years: 2000-2002
ACCUMULATOR ASM,A/C
Part Number: 15-10087
Product Notes:
A/C Accumulator
T/w 15065473 hose & 15065471 hose, identification #15757342; A/C Man; Cont (C60); A/C Auto Elec Cont (C68); RR Aux A/C (C69); 1st design; ; Built w/15065470, for 2nd des see 01132824
Per Vehicle: 1; Years: 2001-2001
OR
ACCUMULATOR ASM,A/C
Part Number: 15-10422
Product Notes:
A/C Accumulator
A/C Man Cont (C60) ; A/C Auto Elec Cont (C68) ; RR Aux A/C (C69) ; 2nd; design ; Built w/15074665, for 1st des see 01132781
(3)AC Orifice Tube
ORIFICE,A/C EVPR TUBE
Part Number: 15-50121
Product Notes:
All Makes-A/C Evaporator Tube Orifice
Front unit, optional automatic adjusting orifice tube for normal ; ; climates (105 deg-)
OR
ORIFICE,A/C CNDSR
Part Number: 15-5378
Product Notes:
A/C Condenser Orifice
1st design ; w/tube dia of 13 mm at the orifice, for 2nd des see, 15784601
Per Vehicle: 1; Years: 2000-2005
AND
VALVE,AUX A/C EVPR THERM EXPN
Part Number: 15-50171
Product Notes:
Aux A/C Evaporator Thermal Expansion Valve
use compnine.com to look for the specific part numbers on seals you need.
P
pstuffy
Thanks for the reply....excuse my ignorance.
What is the difference between the 2 accumulators and 2 orifice tubes you listed?
Thanks for all the help.
SunlitComet
OBS Jedi-Do Good
one orifices is the adjustable. difference in accumulators is probably because of A Technical service bulletin. Run a vin decode on compnine's research page for details on your systems.
Buzzsaw
