AC/Heater Fan control
A
atis
New Bern, NC
Update: replaced the blower resistor...nope, problem still there. Pulled the blower fan and put 12v on her...spins fast as crap. Now the blower works on all setting but will turn itself off and then back on at will. So I am guessing its either the fan relay (which I cant locate, anyone know where it is??) or its the dang fan speed switch.
I did locate a grounding post with wires on it above the blower fan. If you pull the glove box out and look up over top of the blower motor you will see a ground with a few wires attached to it....where they go I have no idea.
SunlitComet
OBS Jedi-Do Good
unknown at this time.
high speed fan relay is on top of hvac unit behind glove box. It just bypasses the resistor and applies direct volts to fan. I think you should look at your fan switch and plug for it.
A
atis
New Bern, NC
thanks, thats one part no one had...even the entire control unit was the wrong part.
A
atis
New Bern, NC
I used everything from 96-03 looking for the right one...none matched the one in my Hoe. I have the 3 buttons along the bottom and none they showed had the bottons!
A
atis
New Bern, NC
Here ya go...
A
atis
New Bern, NC
thanks, I will take the PN to Advance and see if they have it...every picture they pulled up for what they had listed was missing the 3 buttons and looked like it was lacking the AC controls on the right side.
Stevemo70
