AC hose leaking
frankenstien
Fairbanks, Alaska
saw some drops of oil under the truck, assumed it was an axle seal, crawled under there, its the rubber portion of the hose that goes from the ac pump to the lower part fitting of the condenser? the little radiator for the ac.
never worked on ac before on a vehicle anyways, at work we use a machine to drain fill systems as needed to do repair, assuming its the same here? id liek to just replace the hose, but then id guess i need a shop to purge and refill system?
any insight would be appreciated
Austin12
