AC light blinks 3 times when I try to turn it on
genius
the same thing happens iwith my 2002 cadilac escalade!!!!!!!!!1 please help me i'm burning up!
Pauld1585
might have a fix for you.
remove the bezel
remove screws holding in the ac controls
turn truck on
set temp to cold
turn off engine
remove key
disconnect ac module
turn temp to hot
reconnect module
turn on engine
this should hard reset your module. Tried it today for a blinking light and no cold air at 56 F. after plugging it back in I got cold air at the cold setting and hot in the hot setting. before I could only get hot.
SLCHOE
ASE Master Certified + (L1)
Midvale, Utah
The flashing light has to do with a low battery state of charge. Your recent fix of your alternator may fix it but I'd have the battery load tested anyway. Otherwise drive it and see if it happens again. If your battery is good, the new alt will charge it back up and the problem will disappear. Good luck.
Eli B
Western Massachusetts
I just developed this problem. And my heat is blowing cool air. Heard there's a way to reset the climate control by taking out the fuse and disconnecting the battery.
Blesna
