Ac pressure goes up and down what's wrong
ladorn45
Hey everyone was charging my ac with the AC pro charging kit. When I hook the kit to the low pressure vaulve the pressure goes to 50 then the I hear I noise (think the compressor kicks on or off) and the pressure drops to 20. It cycles like this the whole time. Anyone know what's going on
Scottydoggs
NJ
pretty sure it will cycle like that till it reads full. if your going from dead empty.
L
ladorn45
So should i keep filling it up. Im just nervous to keep filling it since 50 is the max point on the ac charge pro guage
Scottydoggs
NJ
as long as it drops back down to the green range on them gauge on the can.
ive been lucky as hell, have not had to mess with any thing ac related for years now.
Randy Whistler
Living the dream! I'm just not sure who's dream
In Hell, but I've got a Tahoe!
Scotty's right. The compressor will cycle on/off in normal operation, with the exception of when you have the A/C set to MAX. In normal operation, the compressor will cycle when necessary to condense the Freon coolant. In MAX operation, the compressor will run continuously.
The readings you're seeing are correct as well, to a point. As Scotty said, as long as your readings stay within the "acceptable" range on your gauges, you should be fine. It will take some practice to feel fully comfortable with the recharge process, but the simplest way to get used to is is what you're doing. Just charge it slowly, watching your gauges, and take your time.
One other thing, too: your Freon can will chill quickly on the bottom when filling. You'll need to swirl the can around to keep it from freeze-locking, but do not use heat!
01ssreda4
Normal with a low charge. Keep filling.
Another thing, during non-use, pressures are the same. There is no high or low side. They settle in around 80 psi. When the compressor runs its sucks one side lower and pressurizes the other higher. When your low side spikes its going back to resting pressure due to the compressor not running. Fill with AC running on high.
steepz
