AC problem 01 Yukon XL 5.3 w/rear air
LordWayback
LordWayback
You likely would NOT need shims with a new clutch. Id be more worried about the possibility of compressor being locked up causing the clutch to slip.
I was referring to shimming the clutch that’s already on there a clapped oem part> Chinese knock off that’s not even carried at a parts store or branded.
LordWayback
LordWayback
If so I don’t think mine is any good looks like corrosion?
LordWayback
LordWayback
After a short amount of time running it like 30 seconds with time to cool it reached past 140* with no compressor actually activating to circulate hot air into the compressor and make it hit normal temps. At this point it’s either a locked compressor or badly slipping clutch to be going that hot without actively circulating the heat , another update the blower isn’t working out of the vents in the front besides side ones and feet ones. I think the switch board as suggested earlier may be messed up both blower fans are working as they should. I’m thinking it’s actuators or the switch being bad but I’m assuming I can ignore that as it won’t stop the compressor from working Atleast for now. from what I can tell the clutch is getting power. My money is on the compressor locking up which sucks, it sounds like the oem coil is in fact activating but I’ll know for sure if the compressor is shot by late Saturday.
LordWayback
LordWayback
On Saturday if possible I’ll double check the refrigerant levels if they’re normal combined with all the diagnostics we’ve done here/ parts it’ll be down to a new compressor/high-low pressure switches. If a new compressor is required I’ll sadly have to take it in cannot evacuate the system myself and at that point it’s already in the shop might aswell install it for a few hundred more.
LordWayback
LordWayback
Well shit, dead compressor that belt was brand new before I tried to keep running the AC.B9BD0AAB-64B3-4FDD-A6C0-E205625CB388.jpeg
jstaguy26
