AC stinks
WalleyeMikeIII
Sunny and Snowy Minnesota
Going in tmw
Just cleaned it again. Air flow is strong. Semi cold in back. Driver side warm Ari on coldest setting
You could have a blend door issue, or an issue w/ the compressor, condenser, evaportor, pressure valve, etc. You are at 15k, Dealer techs know how to work on A/C. Go to dealer, they will fix.
DuraYuk
He is not complaining of a smell, he is complaining of the a/c efficiency. Did you read the entire complaint? Or did you go by the thread title only? I see no where that the OP complains of a smell. You mentioned smell and if the refrigerant is leaking inside at the evaporator, you may smell something or if the leak is bad enough under the hood to come in the vents you may smell something but if it leaks that bad, ir would never actuate the a/c compressor clutch.
Oh snap. Your right (imagine that). He probably has blend door issues. I'm chasing smells over here. My bad OP. Cowl and cabin air filter won't do what your describing. Sorry for wasting your time. It's either blend doors or low refrigerant or both.
I saw the title ac stinks and took it literally lol.
OR VietVet
Multnomah Falls
Military
Willamette Valley
Same as me. The first thing I thought of was a mold smell or something else and then I read it and had to go a different way.
gy_psi
