PG01
so it holds vacuum and no leaks, compressor kicked on but no cold air correct? gotta be inside then.... unless i missed something... blend door, controls. you have rear a/c?
i just reread your post you said dye was coming out of valve, maybe there’s dye and stop leak stuff gumming up the condenser??? in turn giving high high side readings??
just throwing ideas out
Might be worth it to reach out to @UmmScott . He’s pretty knowledgeable in the HVAC systems in these vehicles.
Sorry Mods for putting it in the wrong place. I had initially thought interior but then again I was working under the hood so idk I'm bad at choosing which place to put stuff![]()
No worries about posting in the wrong section. Especially for awesome members like you.
Hopefully you pulled a vacuum and didn't leave that cap off! [emoji16][emoji16]
Forgive me if i missed something. You have front and rear ac yes?
You're pressures are Way Too Low especially at startup.
Even on a nice hot day with the front AND rear system on your low side will start up around 70 quickly pulling down to 50. And your high side will be higher around 250 and come down from there.
Are you getting the full weigh in charge in there? Those cans suck and aren't that accurate but should work if you get the right amount.
Btw 2 small cans is not enough for a front and rear system. I dont think you're adding enough especially with those pressures.
Another thing to help is to check superheat. Pretty easy on the front system. (Superheat is an indicator for how much liquid is in the evaporator and tells you how much work/change of state the evaporator is doing.)
Measure the line temperature right after the orifice going into the evap and measure outlet temp of the evap.
Subtract the inlet FROM the outlet. That is your superheat. If its really really high like 50F or even 30F, then you dont have enough refrigerant feed to the evap: ie low charge, restricted orifice. Superheat on a car should be anywhere from 0 to 20 once its cooled down.
Also (again sorry if i missed this) if you have rear AC. If the rear AC works pretty good but the front sucks or is warmer, you're low on charge. Rear system uses an expansion valve. Exp valves adjust and regulate themselves. The front orifice doesnt. So when system is low the rear will hog all the liquid available.
Hope this helps. Hit me up if u need more input man [emoji106][emoji106]![]()
Sent from my SM-G975U using Tapatalk
