If anyone else needs it:
#08-08-66-004: Procedure to Open Liftgate If Inoperative in Closed Position - Service Plug Available - (May 13, 2008)
Subject: Procedure to Open Liftgate If Inoperative in Closed Position — Service Plug Available
Models: 2007–2009 Cadillac Escalade, Escalade ESV
2007–2009 Chevrolet Suburban, Tahoe
2007–2009 GMC Yukon, Yukon Denali, Yukon XL
________________________________________
If the liftgate were to become inoperative while the liftgate is in the closed position, use the following procedure to open the liftgate without damaging the interior trim panel. The service procedure includes drilling an access hole in the interior liftgate trim panel to release the latch. Service plugs are now available in the appropriate interior color to fill the hole.
Important: Do not remove the liftgate interior trim panel to release the latch. Do not replace the interior trim panel.
1. Locate the dimple on the trim panel.
2. Use a 1 1/8” hole saw to drill a hole through the trim panel.
3. Use a flat-bladed tool to push down on the bellcrank lever to unlock the liftgate.
4. Push the liftgate open.
5. Install a plug in the access hole.
Parts Information
Part Number Description
15836138 Plug — Lt. Cashmere
15836139 Plug — Lt. Titanium
15836140 Plug — Ebony
15836141 Plug — Very Light Cashmere
Warranty Information
For vehicles repaired under warranty, use:
Labor Operation Description Labor Time
C9849* Liftgate Latch Access Hole — Install Plug 0.2 hr
