Active brake stainless braided kit
TheAutumnWind
Russell lines 656040
Adapters 641331
I used cooper rear lines with 3/8 x24 ends that fit directly into Russell caliper lines which came in the kit to replace factory rubber hose. 3/8 x 24 is what -3 an hose is threaded to.
Sent from my SM-G900V using Tapatalk
thanks for the response on this. I've gotta get around to this install one of these days.
D
Duramax05blk
NH
No Problem. Glad to help I would try to contact Russell first to see if they have a kit.
abishoff
I ordered these adapters off of amazon and the factory hard lines off the axle didn't thread into the adapters. This is on my 06 Denali.
D
Duramax05blk
NH
The adapters should to adapt factory hard lines from abs module to the new -3 stainless lines. Axle line should be a -3 thread already
abishoff
So I only need 2adpaters at the top of the line? And the factory hardline should thread into 1 end of the stainless steal line? I assumed I need 4 adapters, 1 for each end of the line.
D
Duramax05blk
NH
Correct should only need them on the top
dylansmashed
