I checked all the circuit connections everything checked out. The knock sensor code was the first one than after that morning I was having misfires it thru up the po300 and po301 so the po201 only popped up once. But pulled it all back apart to double check everything and double and triple check everything again.P0201 is injector circuit malfunction. Unless that was set by error, left key on while unplugging injector, that sounds like the first thing to solve.
I've just got to find out what the voltage should be to each coil pack then each fuel injector in like I've got to figure something out I got to find the information I need and google isn't helping me.. smh
