Actuator working but no 4WD
AZ Tahoe
Arizona
So today I pulled off the transfer case switch it was fine so I pulled the acuator off and put in in 4 lo and the actuator poped. So If I can here the transfer case working and the actuator is work why do I still have no 4WD??? Its a floor shift and the lights go on saying its in 4WD. Not sure what else it could be. Anyone have any thoughts
AZ Tahoe
AZ Tahoe
Arizona
crap, are those visable from under the car. I will do some research on those items tomorrow to see if I can self diagnose
---------- Post added at 05:20 PM ---------- Previous post was at 05:20 PM ----------
On a good note my rear dif was leaking so pulled it painted it installed and refilled. Looks good and the oil was so bad. Will post a pic tomorrow
SunlitComet
OBS Jedi-Do Good
unknown at this time.
uh no a tear down of the front axle or tcase would be required. btw how do you know 4wd is not completely active.
---------- Post added at 05:19 PM ---------- Previous post was at 05:17 PM ----------
actually can you get the whole truck off of all four wheels? there is a test you can try. to narrow it down.
AZ Tahoe
AZ Tahoe
Arizona
Yes I can and I found out the first trip to the lake when I got stuck. Put it up off the wheels to verify
SunlitComet
OBS Jedi-Do Good
not sure if i read that you did verify but at any rate while all four are off the ground have some one apply brakes put into to 4hi wait a few seconds then put into gear. you should see all four spinning with brakes off. if front is not does at least the driveshaft for the front turn or what. details please.
WARNING: DO NOT PUT INTO PARK UNTIL ALL WHEELS ARE STOPPED WITH BRAKES. YOU WOULD NOT LIKE WHAT HAPPENS.
Carlos123
