adding a transmission temp gage
big ken
I have A 04 yukon slt and was looking to add A factory trans temp gage to the cluster. Is all the necessary componets there other than the gage? Also how big of A deal is this to do?
thanks
Phantomx55
Slow
New Jersey
^ ton of help there
Why not just upgrade to an esky cluster? Look 10x better then stock, comes with trans temp gauge, and is plug and play
jwhaler17
Or you could get the cluster from a 2500HD. They have Tranny Gauges as well if you wanted to keep a "stock" Tahoe cluster look.
Mr.Jack
Norway
Is it just plug and play if I buy a cluster with the trans temp? Does the gearbox have a sensor already? With the wires and stuff.
My current cluster does not have this temp meter.
ScottyBoy
Shreveport, La
Yes, it is plug and play. No additional wiring is needed. The transmission already has a temp probe in place and its already wired to the cluster. So I am guessing you will need a KPH cluster, not the one that displays MPH? You need the one with kilometers instead of miles?
Thustlelovemuscle
