adding a transmission temp gage
SC88
Chicago Burbs
Or you could it to this guy: http://stores.ebay.com/SPEEDOMETER-SALES-AND-SERVICE?_rdc=1
I sent mine there for a handful of burnt out bulbs in the cluster....ended up having all the steppers replaced along with an Esky bezel installed. Top notch work.
I've talk to that guy before about doing a Esky cluster for my Burb but with a brighter white backlight... Is the transaction as easy as he makes it seem?
Did all the info come back correctly on the new one?
Phantomx55
Slow
New Jersey
Yes, it is plug and play. No additional wiring is needed. The transmission already has a temp probe in place and its already wired to the cluster. So I am guessing you will need a KPH cluster, not the one that displays MPH? You need the one with kilometers instead of miles?
I swapped an esky one right in with mph
Mr.Jack
Norway
Yes, I do. But a few dealers do have these. Not in such a wide selection as the MPH ones though.
---------- Post added at 12:12 AM ---------- Previous post was at 12:10 AM ----------
This. I had one in my last car. It was the best gauge I had. If a CEL came on I was able to scan and see what the DTC was instantly.
Sent from my myTouch_4G_Slide using Tapatalk
Where did you place this gauge? I doubt it will fit in the cluster itself?
gitrduun
The ones out of the 2500 will read the odometer straight out of the computer right ? 03+ I was told does that automatically ...?
M Hankel
Vancouver, WA
Great info in here. Ive wanted to do the Esky cluster and often wondered if the trans temp gauge would work on a tahoe.
Mike
ChevyFan47
