Adding AMP & Subs to OEM Bose/Navi Head??
vt_hokie2008
VA
Let me know when you find out where you run your power wire from the battery.
I have looked all over the place and can not find a spot to get the wire into the cab.
I ran it with the main grommet to the top left of the brake pedal. I've run 4 wires through there so far. It's easy to get to from under the hood. I used a metal coat hanger and taped my wires to it and pushed them roght on through beside the other wiring.
Sent from my SM-N900V using Tapatalk
DWebPro
Stevenson Ranch, CA
Thank you sir! Just routed the wire between meetings, now I need to hook up the rest and I will finally have some bass!
T
TXSlammer
I watched a video on Youtube where they ran it through an existing whole in the fire wall. That's what I am going to try and do. I am installing this weekend so I will let you know what I find.
Deephaven
Factory grommet is huge. Right above where my left foot sits (size 16 and way up as I am 6'7). I pulled 4@14ga and 2@1/0 through it with room to spare.
vt_hokie2008
VA
I took one of the bolts out if the net anchor in the back and put a ring terminal on the ground wire and put it back on. Works great
DWebPro
Stevenson Ranch, CA
Ahh, I am installing mine under the second row captains chairs.
----EDIT----
Used the ground from a bolt for the seat! everything is firing up now, just need to tap the LOC to the sub wire.
unoigo
Detroit
----EDIT----
I've been looking to do the same thing. Just some subs and an amp. Where did you get the box? I've seen a few on eBay but not sure of quality or fitment.
dylansmashed
