Adding fog lights
Bamajake95
I have a 2007 GMC Yukon sle without factory fogs. I was wondering if I can buy housings, harness, and switch and make them work or what needs or can be done to get fogs on my truck?
Thanks in advance
Sent from my SM-G960U using Tapatalk
I don't know if the existing wiring harness already has the wires built in for the fog light option, of if your bumper already has knockouts built in for the fog light option. If not, you may want to consider installing LED light bars under the bumper for use as fog lights.
93blkongreenpro
Thanks in advance
I've never seen a NNBS without fogs, unless it was a hybrid.
Sent from my SM-N950U using Tapatalk
Bamajake95
Bamajake95
It does have knockouts atleast. But I've heard rumors that the plugs are already up in the bumper just not sure if it's true. I mean I'm probably just going to go the left route anyways. And then wire them to just be on all the time.
Bamajake95
Bamajake95
It won't let me quote but it's not a hybrid, but atleast has knockouts. Also forgive me I'm new here but what does NNBS mean?
BG1988
Thanks in advance
there is a LED option as well by sylvania. it even shows a photo of a tahoe on the outside it's a 4" hole right?
Bamajake95
Bamajake95
3.5" or 4" not sure which exactly
93blkongreenpro
kbuskill
NE. FL.
NNBS = New New Body Style ='07-'14
Slurpglass
Houston, TX
I’m getting ready to install rigid D2 pods to replace my stock fogs. It’s pricey but and easy install since harness and all is included, mounts can be bought separate... I also don’t care that my fogs will be on a separate switch. I’ll post pics once installed.
dacpdx
