Adding wireless charger to 2018 Tahoe LT
George100
The pad was updated for 2018, the new one has 10 ridges on it and old one had 9. I ordered one with the part number that is above in the illustration but it was exactly the same as the one i had. #23264395. I did update the center console to accept an iphone 12 max. I just got a new tray liner, which is part 84017364 and took my old one and just dremeled the edges alittle and the case and phone now lay flat and charge with no problem. I had the black liner and not the silver (thats expensive) and with the minimal trim it does look good. I just bought a new one to give to the new owner in case they wanted to restore to stock.
ptm82379
Thanks for the tip on the dremel trick. I'm probably going to try it. Does it look OK or did the dremel leave it with a gap?
George100
No, the dremel did not leave a gap, i just gradually moved the edges back all the way around, i just give it a little smoothing. I will try and post some pictures.
For an iphone 12 pro max, the phone does fit at the top of the tray but the edges are bevelled down to the rubber pad, its the bevel i smoothed out. Now i did have the black surround and i really dont know how the dremel will work if you have the silver piece.
ptm82379
I have the black tray. Sure post up some pics if you have them, that would be great!
J_seriesaffair
