Adjustable Pedals
SNDHOE
Ive got a 2005 Tahoe and the adjustable pedals are stuck on the short setting and Ive replaced the switch on the door panel that also controls the seat heaters. I can hear clicking when trying to move the pedals in but not out. Is there a part number to order for an updated motor?
915_Tahoe
Your GM Parts Specialist
HELL PASO, TX
Motor not serviced separate, part of the pedal assembly.
Both assemblies are discontinued, depending on which one your truck uses. Will need the last 8 of your vin#
Gm# 89040148
Or
Gm# 89040147
Milan
Before you order a new part, make sure the problem is actually with the motor. I'd check the wiring connections to the motor for any loose wires or corrosion. Make sure the motor's electrical connections are secure and clean.
70Hugger
