As you can remember my infamous "loose rockers thread" I finally found time today to do proper adjustments. I only did this because I noticed a lot of ticking in extremely cold weather.
I did the adjustments with the engine running. I drove the truck first and got it to operating temp. I backed the nut loose until I heard clacking then slowly tightened until the noise went away. I also used my thumb to lightly press on the rocker to confirm no lash. Then I tightened the nut another 1/2 turn and done.
Question- Since I eyeballed the turning a half turn with my ratchet will it matter ? Each rocker nut might be slightly off compared to the others. Does it matter?
Now I also have a check engine light after everything is done. I bet it's from all the sensors I had disconnected to get the valve cover off. I had the intake off because obviously I can't do anything with that in the way. So I had the maff sensor unpugged and the IAT sensor.
I disconnected the both the neg and positive cables for like 5+ mins before I put everything together. I will take the battery cables off again for longer and see if the check engine light goes away.
Otherwise the engine seems to run real good and it's quieter now. No misses or strange noises. I pulled the throttle and listened for weird noises nothing just the loud fan noise.
p.s. it was 52 degrees today so I don't know if the cold ticking is gone. It's supposed to be real cold in a couple days. 50s again tomorrow.
