Advice/opinions needed
TahoeBiggz03
I just bought a 2003 Tahoe 4.8 RWD in excellent shape. Just noticed some grinding or rubbing from the rear end whenever I first pull out of a parking spot, on a hill or at takeoff (especially when cold). Only happens when turning left or right. Then after a few minutes it doesn't happen anymore. Any suggestions or opinions of what it might be? I was thinking "differential". Only happens during initial takeoff.
OR VietVet
Multnomah Falls
Military
Willamette Valley
First thing to do, and least expensive, is remove the cover and inspect the fluid condition and for debris/metal in the fluid. Clean completely out with brake clean and let dry. Reseal and refill and drive to see if quiets down. You may have a problem with the G80, if you have one, but best to try fluid change first.
DoriftuEvo
