InterceptorF
I reinstalled the original engine and ECU back into my 2001 Yukon XL because the engine that I re-ringed from the upullupay had bad piston slap <nightmare>. When I first got the original engine re-installed the starter would try when hooking up the battery. I discovered the battery cable was touching the start solenoid cable. After fixing that it was a boggy start but it did finally start; it then ran ok for about 10 seconds then the engine started acting funny, the service 4wd light came on and the lights on the dash dimmed out. Then it started running correct... then it dimmed out... like there is a loose connection some place? When I turned the key off, for just a second, it acted normal... dash was correct and then the service 4wd light came back on and the lights on the dash dimmed out again. It seems like I have a bad ground or a short somewhere but the grounds all seem ok and I cleaned them just for good measure. How can I discover what is going on? I have an OBD scan tool but no codes are being set.
