after market grille corner light question
haks310
Got LEDs?
SoCal
It is easy bro, it is just a ***** getting your hand in there, unplugging the flasher and plugging the new one in. Take a flash light and look behind the dash, right behind the cig lighters, you should see a small black box, that is the flasher.
It is the whole tail light assembly right? Yeah, they work because they have load resistors already installed.
V
Vinsanity108
Suffolk County, New York
maybe it wont be that hard then, the springs that hold up my cig lighters into the dash are broken:rolleyes:
---------- Post added at 09:12 PM ---------- Previous post was at 09:06 PM ----------
Bah...GL with that.
He doesn't even want to change his own spark plugs.
i cant help it that im lazy.....er i mean busy:sleepy:
qlc1964
qlc1964
if you push up on the relay it will slide off that braket then you can pull it down some to unplug it.
Dhrusso925
