Or something in between?
Here's the story: I bought this 2008 SSV last week, knowing it had a myriad of fault codes. I've gotten everything fixed and cleared up except the "service airbag system".
Option 1 (and what I would normally default to) is buy a Tech 2 scanner or similar and fix it myself.
The only reason I'm hesitant is a. zero experience working on this system; and b. not knowing if the system is just broken or if it's been tampered with. Case in point, a relative purchased another model Chevy used, only to find out later the driver's airbag had been removed and replaced with an incorrect part, and the perpetrator installed some resistors or some such to attempt to trick the computer into accepting the bogus part.
My SSV bounced around between auctions for a couple of years between when the cops retired it and I took ownership. Who knows what's been stripped off, stolen, or swapped in that time.
Given that with airbags, you don't get any practice runs to see if they work correctly or not, I'm leaning toward taking this to a dealer for a complete inspection and assessment of the airbag system.
Your thoughts or experience?
Thanks!
Get the Tech-2 and diagnose and fix it yourself. When it's all over, you'll still have the Tech-2 and learned something. If you take it to the dealer, they'll fix it and you'll know what women really want from a man from reading those magazines in the waiting room.
