Alternator swap
XxBIGxTEXxX
Does anyone know or has a linked on how to swap out the alternator on a 99 hoe so i can do it my self?
SunlitComet
OBS Jedi-Do Good
unknown at this time.
Generator Replacement (CS 130D)
81021673
REMOVAL PROCEDURE
CAUTION: Refer to Battery Disconnect Caution in Cautions and Notices.
  1. Disconnect the battery negative cable.
  2. Disconnect the terminal plug from the back of the generator.
  3. Disconnect the battery lead from the back of the generator.
  4. Remove the upper fan shroud as needed.
  5. Remove the drive belt from the generator.
  6. Remove the generator mounting bolts holding the generator to the bracket.
  7. Remove the generator.
INSTALLATION PROCEDURE
  1. Install the generator. NOTE: Refer to Fastener Notice in Cautions and Notices.
  2. Install the generator mounting bolts. Tighten Tighten the generator mounting bolts to 50 N.m (37 lb ft) .
  3. Install the drive belt to the generator.
  4. Install the upper fan shroud as needed.
  5. Connect the battery lead to the back of the generator. Tighten Tighten the battery terminal nut to 8 N.m (71 lb in) .
  6. Connect the terminal plug to the back of the generator.
  7. Connect the battery negative cable.
conrual777
