Alum GM wheels- clear coat damage
Red Rider
So I have a 2004 Tahoe z71 with factory aluminum wheels. They are generally in good shape, but there are a few areas where clear coat is damaged and pealing, and alum is oxidizing.
How have people dealt with this? I did quick search and not found much.
thanks.
YukonXL04
The Riverboat
Arlington, TX
strip the clear completely, and re clear them. OR just continue to polish them twice a year... OR Paint them.
R
Red Rider
So at areas that clearcoat is damaged, can you just polish it to prevent oxidation? I would rather not have to completely strip and re-coat. That would be too much work. I would probably try to sand and just fix the areas first.
What is the coating on there from factory?
YukonXL04
The Riverboat
Arlington, TX
You could try... Not sure how it will look. As you polish them it will take the clear coat off more though. Took me about 10 hours to do 4 wheels. Sand, wetsand, buff, polish, and then waxed. Problem is the wax will need to be redone fairly often.
3ddi3
