Aluminum heads 2004 Escalade 6.0?
rockola1971
Indiana (formerly IL)
The number can be found on the front lower corner of the passenger side head and since the heads can be swapped passenger to driver side and vice versa the number can be found on the driver side head on the far right corner lower side. Its not uncommon for grime to get there and cover the number up. Passenger side is the easiest to see. Ive seen LS engines with 2 heads with cast numbers that didnt match each other.
jasonsanders42
