Scrappycrow
Here's a compatibility chart from the Lucas site. Red "N" Tacky is calcium sulfonate:Never gave it much thought, I just assumed wheel bearing grease was wheel bearing grease. I usually use Red & Tacky.
I bought these "oem" hubs for the awd denali about 4 years ago, they are genuine gm, made by iljin korea
currently have about 30k on them and they are fine
if you zoom in on the rockauto photo you can see it stamped iljin korea, same as mine
What do you suppose would happen if you mix incompatible grease???.... Nuclear explosion?... lolHere's a compatibility chart from the Lucas site. Red "N" Tacky is calcium sulfonate:
Slightly off the grease topic, the knuckles for the aluminum arms are different correct? If so, does anyone know how Belltech is able to offer the same drop knuckle for both hybrid and non-hybrid trucks?
Interesting. But they are iron correct?The knuckles are different for the different size ball joints. For some reason, they want a lot more money for the knuckle for the larger joints for the aluminum/stamped steel arms.
