Aluminum / XFE NNBS Front Suspension Rebuild
j91z28d1
wait... they want you to pump grease into their hubs?
how would you do this?
j91z28d1
huh must be only on their bearings, because I think the rest are one solid outside housing pressed in
if it works, it might be an upside to be able to grease if that's why they are failing.
I still mean to pull apart my old timkin to try and see why it failed.
kbuskill
NE. FL.
Get to pulling... lol
I am pretty sure all these type of hubs can be greased in this manner.
j91z28d1
when I Google the part number on the besting itself. I get this image.
I don't thing you can grease that thru the sensor hole? but it would be interesting to see if it's dried out inside like lack of grease.
I'll try to get it apart at work when I get a min. 1st of the month is always busy
kbuskill
NE. FL.
Obviously these cutaways are graphic renderings but you can see where the reluctor wheel is that the ABS sensor reads and it looks like a perfect path for the grease to get into the bearings IMO.
Foggy
KS
View attachment 454041View attachment 454043View attachment 454044
These are the ones I bought a couple years ago from SKF (i think)... The good ones.
Haven't had to get into the front end yet, but i got em pre biden inflation, so they'll go on
when I do my new Z55 strut stuff later this year
Jordan0277
