AMSOIL Synthetic Chaincase & Gear Oil Product Code: TCCCN-EA
Freedom Motorsports
Long-Lasting Performance for ATVs and Snowmobiles
Package sizes include:
16-oz. Bottle
16-oz. Bottles (case of 6)
5- gallon Pail
AMSOIL Synthetic Chaincase & Gear Oil provides superior protection and performance for enclosed chains and gears found in snowmobiles, ATVs and general equipment. Formulated with extreme-pressure additives, it helps extend chain and gear life through increased wear protection. AMSOIL Synthetic Chaincase & Gear Oil repels water, while also inhibiting rust, oxidation and foam. Its low pour point ensures superior low-temperature starting, reducing drag to deliver maximum power.
Designed Specifically for Chaincases & Gearcases
To reduce initial costs, some enthusiasts use automatic transmission fluid or gear lube in their snowmobile and ATV chaincases and gearcases. Neither fluid, however, is engineered for these applications. Automatic transmission fluid is a hydraulic fluid formulated without the extreme-pressure additives needed to provide enhanced wear protection, leaving gears and chains vulnerable to premature failure. Automotive gear lube is designed to lubricate hypoid gears and is too thick for proper chain and gear lubrication in powersports applications, impairing circulation and leading to wear and decreased energy efficiency.
AMSOIL Synthetic Chaincase & Gear Oil is specifically engineered to meet the demands of enclosed chaincases and gearcases, providing extreme-pressure protection and low-temperature fluidity for superior performance and protection.
Long-Lasting Protection
AMSOIL Synthetic Chaincase & Gear Oil is a 100 percent synthetic formulation that resists shear and chemical breakdown better than conventional fluids. Its superior base oils and additives provide long-lasting protection.
Extendable Spout for Easy Application
Chaincase and gearcase fill holes can be difficult to access, especially on snowmobiles. Each bottle of AMSOIL Synthetic Chaincase & gear Oil comes packaged with an extendable spout to provide easy, clean application. Prior to use, fully extend the spout, thread onto bottle and remove stopper.
  • Extreme-pressure additives promote long chain and gear life
  • Inhibits rust and oxidation
  • Low-temperature fluidity ensures maximum energy efficiency
  • Lasts longer than conventional oils
  • Recommended for Arctic Cat® Diamond Drive gearcases
AMSOIL Synthetic Chaincase & Gear Oil is recommended as a replacement for the following ATV and snowmobile original equipment manufacturer (OEM) fluids:
Arctic Cat Chain Lube
#0636-029
#4639-363
Transmission Lube
#0636-817
#1639-247
#4639-364
Synthetic ACT Gearcase Fluid
#4639-025
#4639-361
#4639-362
Bombardier / Ski-Doo / Can-Am
BRP recommends XPS Synthetic Chaincase Oil (part # 413803300) in its snowmobile chaincases and ATV gearboxes. Although AMSOIL has traditionally recommended AMSOIL Synthetic Chaincase Oil (TCC) for these applications, that recommendation has expanded to include AMSOIL Severe Gear Synthetic 75W-140 (SVO) as an option for those who desire a product with properties more closely aligned with XPS Chaincase Oil. Going forward, both AMSOIL Synthetic Chaincase Oil and Sever Gear 75W-140 are acceptable for use in Skidoo Chaincases and Can-Am 4 Wheeler gearboxes.
XP-S Mineral Chaincase Oil
#413801900
XP-S Synthetic Chaincase Oil
#413803300
Polaris Synthetic Gearcase Lube
#2871280
#2871478
SCL Chaincase Lubricant
#2872951
#2872952
#2873105
#2873106
AGL ATV Gearcase Lubricant
#2873602
#2873603
#2873604
Yamaha Snowmobile Chaincase Lube
#ACC-CHNCS-LU-BE
SERVICE LIFE
Recommended for the drain intervals established by the OEM.
COMPATIBILITY
AMSOIL Synthetic Chaincase & Gear Oil is compatible with conventional and synthetic chaincase oils. Mixing AMSOIL Synthetic Chaincase & Gear Oil with other oils, however, will reduce its performance benefits.
HEALTH & SAFETY
This product is not expected to cause health concerns when used for the intended application and according to the recommendations in the Material Safety Data Sheet (MSDS). MSDS’s are available upon request at 715-392-7101 or on the AMSOIL Website. Keep Out of Reach of Children. Don’t pollute. Return used oil to collection centers.
email [email protected] for more information or questions.
Referenced from here: http://www.syntheticmotorsports.org...-gear-oil-product-code-tcccn-ea.html#post3877
06Tonka
