Another A/C problem
Y2KpewterZ
Y2KpewterZ
Update: Had to have the lines from the compressor replaced. Apparently it had a severe leak right by the service ports.. $~700 later.. ($180 part, $200 labor, $100 for the performance test and $160 for the evac. And recharge)
Still with Same problems. Blew ice cold for 20 minutes... then warm. I left the a/c on while blowing warm air until i could get to my buddys house to check and see if the compressor was running but before i got there it started blowing cold again.. wtf? I got there and because there was nothing to do besides drink beer i took apart and cleaned out the evap coil.. which was gross as expected. Leaves, bugs, pine needles, and caked with mud. After a good cleaning i took the long way home with a/c on full blast with out a single issue. I hope its fixed lol
Edit: i didnt turn right around and go back to the shop because i picked it up 30min before closing, and the tech that worked on it was my buddy so he said he would look at it when he got off.
SunlitComet
OBS Jedi-Do Good
unknown at this time.
hope so to. without sufficient airflow it will ice up. and probably tripped a pressure switch for safety. could not say for sure unless when it happens i have my laptop plugged in to monitor the switch data.
_Dylan_
STAY FROSTY
I have a similar problem,
My A/C blows cool, but not cold. It's almost worthless and I end up usually just rolling the windows down.
My cheap $5 gauge from harbor freight shows about 25 psi on the low side.
I just put a shot of UV dye into it this afternoon and found nothing. I will check again tonight. I only looked around the compressor and the lines going to the drier and the condenser. Are there any other places to check?
I put a can of refrigerant in it a while back, but as I put it in the gauge did not move at all.
1997 without rear a/c. The compressor seems to be working fine. It's not cycling on and off a bunch. I think the previous owner replaced it. It has an AC Delco sticker on it and it's not very dirty compared to everything else under the hood.
Y2KpewterZ
Y2KpewterZ
Update 2: today was 79*. Beautiful day to have to windows down. Except me. I wanted to make sure my a/c was working.
Wrong
I (unsafely and unreccomended lol) jotted down milage, temp and time everytime there was a 5* more fluctuation on the way to the shop. It was a 38 minute drive, and 28 miles iirc. I filled almost 3/4 of a college ruled note book paper with the amount of times the air temp changed. I was using a freshly calibrated chef thermometer (guess my job is good for something haha)
The lowest it got was 32-4* while the highest being 73* This is while being on max ac the entire time. I did notice at any temp above 60 the air was very damp/humid.. to the point my skin was sticking to the leather and steering wheel.
Wish I had taken a picture of my chart. But its back at the shop. I talked to the tech. He has no idea. I have no idea how long my Hoe will be there either.
_Dylan_
STAY FROSTY
Mine acts the same way. At it's coldest it might be 55 or so, but usually it's a damp 70 degrees.
Y2KpewterZ
Y2KpewterZ
Well i shall keep you informed as this issue is corrected.
_Dylan_
STAY FROSTY
Well, I'm in luck. A friend of mine has high and low side gauges and a vacuum pump. Hopefully I can at least diagnose this weekend and start ordering parts.
Since it appears I have a new compressor, is it likely the old one crapped the bed and clogged up the system?
_Dylan_
STAY FROSTY
I cleaned mine, but did not hose it out. I'll do that this weekend.
