Another Customers 2/3-4 Belltech Kit.
drkhrse00
Dallas Texas
Thanks for all the feedback! Tony hooked it up. The kit has been great and put new life into my Yukon! Makes it alot more fun to drive! I have some more pics posted so you can see the gaps a little better. I have had some settling since i took that pic and the rear sits about 3mm lower. Im doing the camber kit and free travel mod this weekend and will update. gonna bring the front down another 5mm. Also those wheels are ten years old. I got em maybe nine years ago from tire rack as a close out. I had a buddy resurface them two years ago on his cnc machine.
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
you got it man!! thanks again
drkhrse00
Dallas Texas
I did the free travel mod today. Made my own bumpstops. Also started to install my camber kit and realized the kid who did my alignment is an idiot.I had plenty of adjustment left even with a three inch plus drop in the front. The rear end came down about 5mm and i got another 8mm out of the front. Real nice stance. Front is lower than the back,now! I will post some more pics when work permits! Doing and alignment tomorrow,myself!
rollin23s
Austin, TX
Truck looks good, I am thinking about doing a 3/4 with 24s or 26s. Really am up in the air, nice stuff.
ludvball
I am installing this kit this weekend on my stock 03 Denali XL. I am also going from autoride to Belltech shocks. I know I need to take out the RTD fuse to disable autoride. Do I need to worry about any of the leveler sensors, or ay other components that are normally associated with the autoride system?
Also, if I want the rear drop at 3", I should install the spacer, but if I want it at 4", I should not install the spacer? If i don't adjust the keys up front and don't install the spacer, that should level her out?
Tony, thanks for the shocks. I will post pics when done. I got a feeling that I will be looking for wheels this summer (those are still stock).
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
if your only doing the rear you will need another spacer with 3 inch level will sit lower in rear than front. adding another spacer (ie 1 inch top and bottom) will bring it to about level
Rome58
