Another dumb rear only drop thread.
macky
macky
great. can you pm me your price for the mcgaughey 3" drops springs for autoride, shock extenders and the belltech 1" spacer.
also the price for the djm 2"drop springs and shock extenders if they will work with autoride. thanks for all the info.
KMeloney
seems like kmeloney is the only one to successfully lower the rear only on a 07+ WITH autoride. i was all set to order the springs he used until i read on belltechs site that they should not be used with autoride.
Macky -- Why all the fuss? You read correctly. I had this kit installed with a spacer and WITH autoride. There's no problem. Why don't you just go with the Belltech kit?
Their website is pretty bad, so I don't know that I'd put too much stock in it. Also, if I recall correctly, they DO discuss altering the autoride sensors in the instructions, so they much believe the kit CAN be used with autoride.
All I know is that I've had no problem with the kit/autoride, and my installer had no problems installing it. Do what you want, but I think the Belltech rear-only kit will give you what you're looking for.
dougcolleen
