BobHolthaus
- Joined
- May 2, 2023
- Posts
- 96
- Reaction score
- 53
I did not. I never tackled it. Life has gotten in the way.Did you ever get this figured out?
That fawkin thing called life…always gets in the dang wayI did not. I never tackled it. Life has gotten in the way.
Thank you for sharing this. These are the posts we all need, when someomeI have a 2021 Yukon Denali 6.2L and recently was successful in prodding my local auto-shop to install a front receiver. They don't make one for 2021+ Yukon so I bought one for a 2021 Seirra 1500 6.2L and it fit well-enough. The driver's side frame was OK but the passenger side frame had a little metal bracket on the driver's side of the frame that interfered where the bolt would go thru the frame from what they said. See final posts on this thread https://www.tahoeyukonforum.com/threads/front-mount-hitch-2-receiver-for-2021-yukon-denali.143264/ for more info.
The auto-shop was hugely concerned about messing with the front / affecting the electronics but the receiver sticks out below the bumper / no issues.
My guess, it's worth a try? seems like a competent installer can take off whatever they need and just put it back if it didn't work? - that was my argument with auto-shop and they agreed they could put things back if they didn't modify anything
Installed tow pin on a 2024 Tahoe High Country diesel. Had to grind a little on the purchased bracket so it would slide into the frame. Remove the plastic section on the lower bumper. Bolt in place with a few bolts. Now, I have a pull hook on the front. It would be very difficult to secure a strap onto the frame or axle if stuck if you don't have this...I have done some more research but have not actually purchased the parts to verify. There is a front tie down bracket (GM part # 84680941) that is listed to fit 2021-24 Suburban/Yukon/Escalade vehicles. There is a front tow eye (GM part # 84452971) that is listed to fit 2021-2024 Escalade’s only. Not sure why the tow eye won’t work on a Suburban or Yukon or if it’s a description error.
The tie down bracket bolts to the driver side frame rail. The plastic cover is popped off and the tow eye screwed into the tie down bracket when needed.
Matt from Matt's Off Road Recovery would give you a thumbs upInstalled tow pin on a 2024 Tahoe High Country diesel. Had to grind a little on the purchased bracket so it would slide into the frame. Remove the plastic section on the lower bumper. Bolt in place with a few bolts. Now, I have a pull hook on the front. It would be very difficult to secure a strap onto the frame or axle if stuck if you don't have this...
