Apach 031
- Joined
- Jun 20, 2021
- Posts
- 19
- Reaction score
- 40
Hey folks. Another HVAC post. I haven't seen this exact same issue discussed before. As the weather warmed up this spring, I noticed my AC light was blinking, and wouldn't engage. Further investigation revealed I couldn't changed the mode at all. Stuck on heated defrost.
So far, I have changed out the recirc door actuator and mode door actuator. And the HVAC control unit. When I hook up the tech 2, it gives me B0423, B3779, B0228, and, B0413, all symptom 61. When I use the tech 2 to try and command them to change position, they won't budge, but all of the rear actuators work fine. When I do a recalibration, nothing changes. I was having the same issues with the old and new HVAC control unit.
I installed a new head unit over the winter, and thought maybe a messed up a connection to the control unit. Traced all wires back to the actuators and checked plugs...they seem fine. In I should mention that when I switched out the recirc actuator, it was out of range. But I have triple checked the new one, it's still within range, and won't budge.
I'm at wits end. Any ideas?
