bigdog9191999
well as the title indicates, having issues with reduced power on or 03 denali. I haven't done too much with it yet, but pulled some codes. a couple that I knew where there, and a couple that surprised me a little, but not too much if there is other electrical issues. guess it is time to get after them.
it started not long ago and did it twice the day it started doing it. this seemed to stay pretty consistent for the next week or so, so till she took it one night and on her round trip of about 60 ish miles it did it 9 times total during basically a blizzard ( and the truck it white, so a white truck along side the road in a blizzard is less than ideal) so she is driving the Tahoe and I am running the 2500 burb daily for couple weeks.
codes as follows.
p0134 - O2 circuit insufficient activity bank 1 sensor 1
p0135 - O2 heater bank 1 sensor 1.
figuring the heater code popped up first, just haven't changed the sensor yet. will change that and go from there
p0452 - fuel tank pressure sensor circuit low voltage
p0463 - fuel tank level sensor circuit high input
p0522 - engine oil pressure sensor circuit low voltage
p1516 - throttle actuator control module actuator position performance
hoping the ground wire fixes will take care of most of this.
will be doing some ground wire upgrades, planning on doing pcm, body, engine and probably an upgraded wire for the power from the alt to the battery. as well as check the wires at the tb and go from there.
will do updates as I have time and weather to get things done.
edit to add that I have been using an aeroforce scan gauge to read and clear codes, as my dongle for torque wont work on this truck for some reason. but when/if I need more I do have hptuners also.
codes as follows.
