Disclaimer: Links on this page pointing
to Amazon, eBay and other sites may include affiliate code. If you click them and
make a purchase, we may earn a small commission.
If it's 4wd you can definitely run without your front drive shaft.
The 2wd front hub bearing is definitely different than the 4wd unit. Do not drive without the outer CV installed and torqued, the bearing will come apart because the drive axle is what holds the bearing together.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
