Antifreeze leak. Please help
laprodigy001
laprodigy001
Did some looking around this morning and the leak seems to be coming from the valve cover area. Here is a pic.
laprodigy001
laprodigy001
I have never replaced the gasket since i had the truck. Which is about 2 years now.
drakon543
That pic does appear to be a bad intake gasket. Is your oil milky looking at all?
laprodigy001
laprodigy001
My oil just looks dirty. Not thick or milky at all. He is doing my intake Manifold gasket tomorrow for $120
DallasTahoe
Try tightening the bolts just a lil bit, mine was leaking from the same place, just tightened it a lil bit and it stopped, but it only a temporary fix, replace the gasket asap! if that is where it's coming from. However the amount of coolant leaking out and the squeaking says water pump, I would change it anyway just to be safe
laprodigy001
laprodigy001
I got a new water pump, thermostat ,idler pulley that they are going to install along with the intake manifold gasket kit.
Regulator23
