Any bulbs out there to replace the ugly DRL on an 08 tahoe???
sumo
dn ʇǝƃ ʇuɐɔ & llǝɟ ı
rhode island
took a few pics. Drls, and then drls with running and fogs. Switchbacks turn signals that flash white and orange.
felixgun
Lafayette, LA
the Drl are 3157. Those are the inside ones.. The one s on the outer are turn signals/running light. Fog are a 5202 led. They dont put any light on the road, but they look good and a great alternative to hid as you wont melt the lens.
Basically all the bulbs. Drl, running/turn and fogs are the same brightness. They can be seen plenty far away. Ill post better pics tomorrow as its ****** outside right now.
Can you post a link of the exact one you got? Yours look GREAT. Is that the Amber stock turn signal and LED aftrmarket turn signal in the last pic?
I'm ordering 4 for my DRL/Turn signals. :Handshake:
sumo
rhode island
I'll post links when I get home. The amber is called switch back. They are amber and white leds in one. They stay white until you signal. Then they alter white and amber.
sumo
rhode island
ok since autolumination website is kinda difficult to navigate, ill have to walk you through. dont forget youll need 2 6 ohm resistors
http://autolumination.com/3157_3156.htm
for drl go to 7 Watt Eagle EYE SMT Tower. 24mm diameter x 52mm. You want the 3157 dual circuit super white
For turn/running lights scroll until you see Switchback. i went with 48 Led SMT Tower Style (25% brighter) you want the 3157 amber/white
felixgun
Lafayette, LA
yes you can. I did. I have a total of 4 one for each turn signal.
Oh ok. I never used the two I originally ordered for my g4 led tails. Just making sure I can use those. Thanks. Oh and one of my cheap eBay SMD led drl's just went out yesterday. Perfect timing.
THE YETI
Director of Operations
South FL
hmmm.... do want!
Do they have anything to make the back up lights really bright too? About to do the escalade tail lamp mod. :secret:
sumo
rhode island
They do have a led for reverse but since led light isn't focused like a regular bulb, you really don't get the light where you need it the most. Oh I thought you were selling the esky tails
kjetilaf
