well the springs are worn. and the trailer has to much weight in front of its axle. and because of the pintle and height of trailer a weight distribution setup wont work either. so if this is the trailer you will primarily use you have three options. replace the leaf spring and drop the trailers height to match the suv and switch to a ball hitch to use weight distribution device. replace the leaf springs and install Firestone ride rite kit when unload the air bags would only have 5 psi in them for safety and reliability concerns. or just use the ride rite kit to hold the vehicle level when loaded and unloaded you would have to adjust the pressure in each bag each time a height adjustment is needed. this process can be automated at an extra cost to to auto level. the last two options will not change the fact that your front end is still gonna lift some and in some road conditions that can effect your braking and steering ability. as long as trailer has that much weight in front of its axle it is going to weigh you down and worse when loaded only effect the front end control of suv even more.
Ok, first.
What a weight distribution device?
Got it....
http://auto.howstuffworks.com/auto-...itches/towing-weight-distribution-systems.htm
