Anybody know what these are?
a4edwin
ny
Found both of these next to the fuse box the relay and the connector. Are they normal or was something added or rigged!?any help is appreciated.
Bill 1960
Testing the Limits
What about the cable or hose laying across the brake lines? That’s does not look original. Going to chafe like that probably.
A
a4edwin
ny
That’s a ground cable I ran from the firewall to the alternator bracket it is too long. I need to trim it and crimp another connector on to it
The hot and trailer brake wires for the rear 7 pin trailer connector. Both are left coiled and taped.
No need to connect them if you don't run a brake controller, or need AUX power to a trailer. if you do connect them, you'll likely need to add the appropriate fuses in the fusebox, that's if you want them to work.
A
a4edwin
ny
Good to know! I’m not a fan of things like that cause you never know what might of been done to the wireing of the truck
rsetareh
