Anybody running E85
04Hoe
Why would anyone run it?
It may cost less, but is proven less mileage and power. I see no benefit in its use.
Grocery Getter
A guy with a truck.
Phoenix, Az
Less power....... Um not so much buddy. E85 is 105 octane and and has more power. It is 25-30% less efficient but 25-35% less expensive then 91/93 octane so u get more power and save a buck or two a tank. If ur running 87 in ur rig you clearly dont give a crap anyway so I reckon it wouldn't make sense either way.
blueflamed03
Oklahoma
just good conversation, but isn't too much octane rating almost as bad as not enough? I mean I go to drags all the time, and guys say "don't think by adding 110 to the car will make it faster, when 105 will do", and it's the same cost. Wouldn't it have the same effect, unless the motor is higher compression? (E85 compliant)
TogaPC
Austin, TX
I've done a little research on this and it turns out that E85 is at least 107 octane and the standard is 108. This means that your engine can advance the timing without knock and produce more power. It does have about 25% less energy than 93 octane so it requires more fuel.
Asked Justin at Black Bear about it and he said "it should make your truck run like a bat outta hell but your gas mileage will suck". I can vouch for this. I'm on my second tank and I do feel a bit of a difference. My mileage is suffering a bit but not too bad.
A word to the wise, if your vehicle is not flex fuel, don't run it. It will corrode your seals and you're ECU isn't setup to compensate for the higher octane and air/fuel mixture.
Other than that it's $.70 cheaper here and has a little extra punch so for around town I'm happy with it.
Jay
Just FYI, a 12-12.5:1 compression engine running E85 will get the same or better mileage as our 9.5:1 stock engines do on pure gasoline.
But the high compression engine running on E85 will make significantly more power and run cooler at the same time.
I like running a full tank of E85 in my 07 every 4th tank or so. Keeps the insides all clean and it does get a noticeable power increase with the more aggressive timing.
Plus the bulk of the money you spend on it stays right here in the USA instead of going to those pesky little countries that don't particularly like us.
sumo
dn ʇǝƃ ʇuɐɔ & llǝɟ ı
rhode island
wish it was around here in RI or close to so i can try it for myself
bahollis
Lead Foot
TEXAS
When you guys say there's a .70 cent difference are you talking about E85 to Premium Unleaded? There's only a .14 cent per gallon difference in my neck of the woods between E85 and 87 Octane. Even E85 to Premium it's only .40 difference.
I have run it in my truck, and it ran like shit.. and yes it's flex.
TogaPC
Austin, TX
Yeah, I'm talking about E85 to premium. I have a 93 octane tune and so it's either premium or E85. Not sure why you're truck would run worse on E85. Most find you get a bit of a power increase from it but gas mileage sucks. Keep in mind that E85 is 85% ethanol which acts like a fuel system cleaner. It's possible that you flushed a bunch of crap from your fuel tank into your filter especially if you've never ran E85 before. It's also possible that you got ahold of a bad batch.
Overall, I'm pretty impressed with E85. I know all the negative points but i'm averaging about 3 mpg less on it and getting a good bit of extra power. It's worth it to me for around town. On the road i think I'll stick with good old 93 octane premium.
Danforth
