Anybody tried running these Sway Bar End Links?
ATIII
ATIII
Brighton, CO (Denver)
I have a set of these on my 2500hd, they work great, ill grab a pic of mine, im pretty sure you have the clevis turned 90 degrees off.....not trying to be a D#$%, just saying....
That's the only way you can put them on a 1500. Otherwise they hit the CV boot.
They're Sturdy ass f**k, as I was breaking stock straight bolt links all the time.
On a side note they squeak a lot (rubbery sound), I hit them with some blaster when I put em together but not sure if I need to go back and actually grease the shit out of em. Anyone have any suggestions?
frankenstien
Fairbanks, Alaska
i put mine together with grease, no squeaking for me. i would try to grease the hell out of them, with the extra side load with it being in there other than intended, greasing them might be regular thing, to keep that upper bushing happy
i attached a pic to show what i meant, i know you had to put them in upside down to clear. just want to make sure im understanding you
ATIII
ATIII
Ah I see, yea maybe I need to twist it so the bolt through the clevis is going from front to back rather than side to side. Correct?
frankenstien
Fairbanks, Alaska
correct, turn the clevis part 90 degrees, so the bolt that holds it to the link end is running parallel with the tire, then the link will be able to articulate as the suspension moves, and it wont be pulling at it on a funny angle
AppocAlexx
Darth Appocalexx
Abilene TX
Those do look pretty good, ill have to keep this thread and get back to it when I do my lift.
They look great installed!!! Well done! But damn you got some killer angles and need UCAs. How does it feel now?
those UCAs are SCREAMIN!! lol
whitey hoe
I just installed them and seems like a much smoother ride than before and I installed upside down like ATIII.No noises yet ,seem to work great sofar
dylansmashed
