fyremanpat
Fyremanpat
jus get the kit for our trucks. its way worth it in the long run. everything bolts up and you only have to drill two holes for the bottom supports and it comes with everything you need..and you can adjust fan speed.
I have this harness @ the house, do you think it will work or should i get a new one?
http://www.autozone.com/autozone/catalog/parts/partsProduct.jsp?itemIdentifier=326161_9583_0_&skuDescription=Compressor+Works+/+Electric+Fan+Thermostat&brandName=Compressor+Works&displayName=Electric+Fan+Thermostat&categoryNValue=16399999&sortType=&store=110&isSearchByPartNumber=false&fromWhere=&fromString=search&counter=0&itemId=1768-0&navValue=16301768&filterByKeyWord=electric+fan+&productId=326161&searchText=electric+fan+&categoryDisplayName=Cooling+%26+Heating&parentId=63-0
I want to try the Lincoln fan.
I used a similar one to do fans on an old '90 s-10 that I was fixing up and it worked great... I plan on picking up a similar one once I get the fans....
