anyone do E-fans on a obs??
Status
Not open for further replies.
AtomicHoe094
Atomichoe094
cleveland, OH
Well make sure all your wiring is first before you start deciding what fuse to put in it. How many amp is the fan? post up pics of the wiring you have.
Limited
It's not wired up yet. I was goin to run 2 40A relays, and try and do what onebadsuv did.
---------- Post added at 06:15 PM ---------- Previous post was at 06:04 PM ----------
Where is the temp switch wired to?
---------- Post added at 06:16 PM ---------- Previous post was at 06:15 PM ----------
What is the temp switch wired to? Where?
bluebear15
wisconsin
The Ford efan is wired in where the "FAN MOTOR" is shown in the diagram - You need two bosch relays to split the load and a temp probe thermister to activate/deactivate the fan (where it says TEMP SWITCH) which is mounted to the radiator core . You can control the amount of run time the fan is "ON" by simply varying the placement of the probe ... if You put it next to the radiator inlet , the fan will kick in and run alot . If You mount the probe near the outlet like I did , you let the radiator do most of the cooling and the fan only comes on if there is no air moving through the radiator , like at a traffic light or sitting idle . Turning on the A/C will automatically power on the fan using the supplied wiring diagram plus manual override switch . I don't take the credit for this sweet wiring setup - I found it on the 'net posted by some kind soul :)
Best one I've found to date , and there are many floating around .
thats the pic of the wiring diagram again
Limited
I got the diagram except the temp switch. Does it only have a ground? (Looks as such) Where can I get one?
Limited
Can I tap into the coolant sensor near the thermostat?
Status
Lane_Bo
