Anyone install JL Audio stealth box?
ACEC7Z
ACEC7Z
I installed the JL Stealthbox, JL XD300/1v2, AudioControl LC2i PRO, and John at Audio Integration Solutions’s wire harness to tap into the existing BOSE system harness.
It’s crazy how much bass a single 10” sub added to the system. It’s a pretty straight forward install assuming you’ve installed car audio previously. I installed the amp and LoC in the shallow storage area in the cargo compartment. I routed the LC2i knob right next to the USB ports right above the wireless charging pad. My only recommendation is that depending on how you want to route your amp wire, you’ll probably need 25ft on the 4 gauge wire. I thought I could get by with 20ft, but came up short by at least 3ft by routing it back across to the driver side in the engine bay.
Awesome thanks for the input!! Think I'll end up getting almost identical setup.
Boosyed96GSX
Orlando, Fl
Hey, could you clarify what kind of harness you had made from John? I’m looking to add a stealth box to my suv and want to track down all the parts before the box gets here. I have the amp kit, amp, and stealth box. I’ll search an LOC next but was curious what the harness you used was for.
Also, where exactly did you hid the amp? I was hoping to put it near the stealth box itself and minimize running wires all through the cabin.
iamlegion
There’s another thread where a couple of us posted pictures on this including myself.
There are harnesses to grab the amp speaker outputs and send to LC2i. I used the sub high level lines, some who don’t have the higher end Bose may not have a sub to tap into.
There are also harnesses you can plug inline to the rear amp that disables the ANC microphone so you don’t get a hum and don’t have to cut the harness.
Boosyed96GSX
Orlando, Fl
Thanks, I’ll see if I can find that thread.
Do you have a website to the harness(s) needed?
iamlegion
Make sure you get your radio RPO code correct.
If I could do it all over again, I would have modified the ANC bypass harness with a switch. Sometimes when I don’t need the sub - like on road trips with the family I would have liked to be able to switch the ANC microphone back on and the sub amp off.
Kpwweb
I did not install the JL Stealthbox, but instead the Cadillac Escalade sub box, a 10” Audiocontrol shallow sub, a 500w kicker mono key amplifier, an LCi2 speaker to line converter with harness, and ANC microphone harness. It is amazing the bass retored by the 10” sub. Went through the key setup process to restore lost bass. Love the setup.
I looked at the Stealthbox, but could not justify the spend for the squeeze. Just offering an alternative here.
To each their own.
Smityinms
