Anyone running 305/70 16's or 33x12.5?
SunlitComet
OBS Jedi-Do Good
unknown at this time.
any of you with 285/70/17 with a non lifted 4dr 4x4. did you need to trim at all? i am due for tires and want to get some big ones if i can.
Badgerdave
305 70 16 on weld 16 x10 .4 inch body lift
AsphaltCowboy
I have a 1997 Yukon with a 2" lift. Someone threw on some Chev 18" wheels, and currently there's 265/65/18s on them. No rub at all and full wheel lock is fine. The tires are fairly bald and it's snow time, so I found a great deal on some used BFG KOs with 80% left. They are 285/65/18. I don't know what offset the wheels are and same with any spacer. Think the 285s will fit?
holt1850
Just curious to see some pics of an OBS with 305/70 16's or 33x12.5.
I've finally made up my mind, and have decided to just add a 2" rear block and crank up the TB's a little. It'll do till I can afford a real 6" suspension lift.
Only thing I can't decide on is tire size. I'm gonna go with some AR Crater
16x8 rims with 4.5" backspacing. I am trying to decide between a 285/75 16 or if I want the tire to stick out wider with a 305/70 16.
Both tires are bascially the same height but the 305's are about an inch wider than the 285's
Any pics or opinions are appreciated
Mine r 285/70/16
Sent from my LG-H872 using Tapatalk
lordmorgul
